cwangnick
May 13, 2018Aspirant
ReadyNAS Is Offline
Hi,
When my Readycloud starts up it shows me "offline". I think it is because the IP address of my NAS changed as I installed an Orbi WLAN which now servers as the primary node for all my devices (...
May 14, 2018Guru - Experienced User
You shouldn't need to tell ReadyCloud the new address, because the NAS will connect outbound to ReadyCloud. You could try rebooting the NAS, and see if that helps.
What firmware are you running?
Do you see the green checkmarks for internet access and readycloud access on the cloud page of the admin web ui?
Note that local access to the admin UI is a convenience feature in ReadyCloud, as you can just as easily log in via https://nas-name/admin or https://nas-ip-address/admin.
