55north
May 18, 2016Initiate
Readynas Replicate
After migrating my ReadyCloud account to a MyNETGEAR.com account i can't log in to the Readynas replicate page. My ReadyCloud works ok after migrating but when i try to log in to my replicate setting...
- May 19, 2016
Hi 55north, MugiMuc, ReneC,
You need to use your old account (the one that you use to login before) which isn't the migrated ReadyCLOUD / My NETGEAR account.
Kind regards,
BrianL
NETGEAR Community Team
kohdee
May 19, 2016Administrator
If your ReadyNAS Remote ID (which is used to login to ReadyNAS Remote and Replicate) was used to login to a ReadyCLOUD account, and then you upgraded it to a NETGEAR account, try your NETGEAR account password with your Remote ID to login to Replicate.
