55north
May 18, 2016Initiate
Readynas Replicate
After migrating my ReadyCloud account to a MyNETGEAR.com account i can't log in to the Readynas replicate page. My ReadyCloud works ok after migrating but when i try to log in to my replicate setting...
- May 19, 2016
Hi 55north, MugiMuc, ReneC,
You need to use your old account (the one that you use to login before) which isn't the migrated ReadyCLOUD / My NETGEAR account.
Kind regards,
BrianL
NETGEAR Community Team
MugiMuc
May 20, 2016Aspirant
SOLUTION:
Thank you, this did the trick.
Important: As "Remote ID" use the old ID (not the ReadyCloud email address) you always used to login to replicate. For the password use the READYCLOUD password. The same password you used for the migration with READYCLOUD.
Thomas
