Raven1938
Mar 14, 2017Aspirant
ReadyNas VPN diconnected
Hello Netgear Community, I've read about 20 posts on this topic this morning, but failed to find any solution that would help. Essentially, I have a workgroup of 5, and 3 are currently connected ...
Mar 14, 2017Guru - Experienced User
Raven1938 wrote:
...while trapped inside do to a Nor'Easter (Blizzard, for those who are unfamiliar).
I'm in Boston, so I am very familiar.
Raven1938 wrote:
I am communication with three users who are able to connect, anything they can do, as non-administrators? Anything I can do,
I wish there were a good answer on ReadyCloud. All I can suggest is looking at other alternatives. It just doesn't have the reliability.
Google Drive or AWS sync are possible, but it's still early days for them. OpenVPN, OwnCloud or ZeroTier seem more stable.
Another option is to install Filezilla on everyone's PC, and forward FTP ports in the enterprise router. Use ddns if there is no DNS in place already. Then use FTPS as a backup access method. You could potentially get this running today if you have remote access to the router configuration.
