larsgeln
Jun 25, 2024Aspirant
READYNAS10200 hard drives don,t start up
Last week my NAS 102 did not respond. I local PC-guy looked at the problem and told me to buy a used NAS102 as the drives looked healthy. So I bought a used NAS102 on eBay. The new one connects but b...
Jun 25, 2024Guru - Experienced User
larsgeln wrote:
Last week my NAS 102 did not respond. I local PC-guy looked at the problem and told me to buy a used NAS102 as the drives looked healthy. So I bought a used NAS102 on eBay. The new one connects but but say no folder on my PC.
Can you access the NAS admin web ui? Browse to https://nas-ip-address/admin (using the real IP address instead of the nas-ip-address placeholder)
You can find the NAS IP address in your router's attached device list.
- SandsharkJun 25, 2024Sensei
It is unfortunate that you jumped to the conclusion that the enclosure was bad because somebody told you "the drives looked healthy". The typical problem here is with the contents of the drives (specifically the OS partition), not a hardware failure of either the drives or the chassis.
Continue with what StephenB is advising. But also re-connect your old NAS to your network without drives and see if RAIDar recognizes it. If it does, and you have a spare SATA drive (containing nothing you care about and definitely not one of your drives that were in the NAS before), see if you can create a new volume on it. This will help determine if the chassis really is bad (which may have also caused an issue with the drive contents), or if there is something else wrong.
- larsgelnJun 26, 2024Aspirant
See my answer to StephenB.
Thank you.
Regards
Lars-Goeran
The old NAS did not respond to https://nas-ip-address. The new one did. I got a safety warning. I bypassed the warning and typed the usual password. Got into netgear and netgear answers "can't acess the drives" . That was happened yesterday also, but first I was advised to update from V6.10.5 to V6.10.10. Powered off and swapped the drives. Powered on again but no better result. I stopped on this step and did not push "next". I will not risk the old drives maybe to be reformated. I have no empty spare drive. Can I go further or is it better to use R-linux I have read about in this community.
I have a SUB connected hard drive I use to back up my NAS. But the latast is since 2020! Can this device be used as SATA adaptor for one of the NAS-drives and get the files using R-linux.
Regards
Lars-Goeran- StephenBJun 26, 2024Guru - Experienced User
FWIW, that was waste of time.
R-linux won't work with an RN102. You could use something like ReclaiMe (which supports both linux software RAID and BTRFS). While that is not free, you can download it for free and see if it can find your files.
One thing that would also be useful is to run the vendor diags on the drives. Seatools for Seagate, Dashboard for Western Digital. That would require connecting the disks to a Windows PC (either with SATA or a USB dock/enclosure).
The warning is usual, but the message is not. Was the NAS actually asking you to do a factory install? Can you post a screenshot?
Also, can you download the log zip file from the logs page of the web ui?
- SandsharkJun 27, 2024Sensei
Note that I did not ask you to swap the drives back to the original unit, and doing so was not a good idea if the chassis really is bad. I asked you to connect the old NAS with no drives installed and see if RAIDar recognizes it.
- larsgelnJun 28, 2024Aspirant
No respond at all.
Regards
Lars-Goeran
