chaplinmm
Jan 12, 2019Aspirant
ReadyNASRND2000v2 not starting up
Hi All,
I have a hard drive in my readynas duo v2 but it stopped starting up when the hard-drive got 100% full. The harddrive is healthy as I plugged it into my computer and it was found and the system (windows 7) said it was a healthy harddrive.
But the readyNas wouldnt boot, the ReadyNas works fine when I remove the harddrive and it can be found in Raidar. But when I put the harddrive back in it has errors on the Raidar, I read somewhere that the logfiles most likely couldnt be written (HD full). How do I fix this?
The blue power light just flashes on and off and then on for a second and act light flashes on and goes off again.
Can anyone help? How do you bypass the logfiles being written? I can login to telnet but what do I do after that?
What firmware is running in the Duo?
Do you have a backup of the files on it?
- chaplinmmAspirant
Hi,
The firmware is the latest version, I can't get the version up as it's not booting with the hard disk inside.
Most of it is backed up but not the last 2 months.
Kind regards,
Andrew
