Tomski72
Jul 09, 2017Guide
ReadySHARE works but ReadyCLOUD cannot discover USB_Storage HDD connected to my R7000 router.
I have an Iomega Prestige USB 2.0, 500 GB desktop HD connected to the USB 2.0 port on the back of my newly installed R7000 router. I was able to map the HD as the U: drive using Windows 10 on my des...
- Jul 10, 2017
Deniro, if I go to the ReadyCLOUD Portal and try to create a ReadyCLOUD account, I eventually end up at the screen shown below:
No matter from what NetGear-initiated screen you are on, if you click on a ReadyCloud page that says to click here to create a ReadyCLOUD account, you will always end up on the above page. Then to prceed, you must click on the "Discover" option which leads to the Catch 22 where ReadyCLOUD cannot discover your device, so you can never create a ReadyCLOUD account because the device will never be discovered.
However, I had a "Eueka!" moment. If I started at the R7000 router page below:
The key to this screen (and all other NetGear pages that tell you to create a ReadyCLOUD account) is to NOT click anywhere it says to create ReadyCLOUD account by clicking here. Instead, Ignore these instructions and on this page (above), simply enter the User Name and Password that you used to register your router with NetGear!
This advice to ignore the NetGear instructions should be passed on to all the NetGear tecnical support staff, and to someone in charge of writing all the tech support articles (I must have read at least 10 to 15 of them), and to the person in charge of programming the above screen. All that needs to be changed on this screen is to add the sentence: "If you have already registered your router with NetGear, you can simply enter your NetGear login credentials here, and a ReadyCLOUD account will automatically be created (ignore all the "Click here" options shown above to create a ReadyCLOUD account)."
Deniro, if you have influence with the NetGear support/technical staff, could you please pass on my thoughts and recommendations. I spent a couple of hours with tech support staff, probably 6 hours reading and studying NetGear articles, and 8 hours trying everything I could to make this work before I simply ignored all the instructions that said I had to create a ReadyCLOUD account before I could do anything else. This is not true if I have already created a NetGear account for my router!
Tomski72
Jul 09, 2017Guide
I need to add that I have also tried to ReadyCLOUD "discover" the HD by inputting its serial number. Also, RAIDar cannot discover the HD.
Retired_Member
Jul 09, 2017Hello Tomski72
ReadyCLOUD does not support router device discovery,you can register your router device in Router admin GUI directly.
to register ReadyCLOUD on router please check below URL link
- Tomski72Jul 09, 2017Guide
Deniro, thank you for your reply and suggestion. All I can say is, "Been there, done that." No matter how I try to do this (and there are several ways to get there), I always end up at the following page:
http://readycloud.netgear.com/client/index.html#page=access
The process to create a ReadyCLOUD account (no matter where you start from) always starts with "If you do not have a ReadyCLOUD account, click here and click on "Create Account"." When you click "here" to create a ReadyCLOUD Account, you are sent to the above link. ReadyCLOUD will not let you create a ReadyCLOUD account unless you have a registered storage device. And if ReadyCLOUD cannot discover my shared storage device, it will not let me create an account.
It's really a "Catch 22." My router is registered, but ReadyCLOUD doesn't care. I cannot create a ReadyCLOUD accout without it discovering a storage device. If there was someway to create a ReadyCLOUD account without doing that first, maybe it would work. But there is no way to create the account without a "Discovery."
- Retired_MemberJul 09, 2017
Hello Tomski72
have you registered ReadyCLOUD on your router with your MyNETGEAR account?you can create MyNETGEAR account in ReadyCLOUD portal
- Tomski72Jul 10, 2017Guide
Well, I don't know how to paste a screenshot into this forum's discussion pages. Could you please tell me what kind of file is allowed to be pasted into this discussion, or do I need some special permission?
