Mrwolf444
Dec 04, 2020Aspirant
Redy NAS 212 .tpm files and Word temporary files
Hi It is since a couple of months that in my shared folder I find a lot of .tmp files and temporary Word files. I have tried in moving the .tmp files to a local diretory but nothing changes. It al...
Dec 04, 2020Guru - Experienced User
Is this happening with Macs or with Windows PCs?
Generally the issue is on the PC side, as the NAS isn't creating (or deleting) these files - the application on the PC is doing that.
Mrwolf444
Hi
We use only Windows10
- StephenBDec 04, 2020Guru - Experienced User
For word, you might want to check the autorecover settings that it is using.
There is one in particular you could try changing, which is "keep the last AutoRecovered version if I close without saving". Of course this would mean that if someone does close w/o saving that they'd lose their work.
You could also check the file owners, and see which users are creating them (though that assumes that the users are all using different NAS user accounts).
- Mrwolf444Dec 04, 2020AspirantHi
I have already tried that way but it didn't work.
The shared has "everyone" access so it doesn't need the user to authenticate
