SergeyGP
Feb 08, 2021Aspirant
Registration problems
Recently bought a used ReadyNAS Duo V2. I can't configure it correctly. I registered it on the site, but the configuration program says that you need to register the product. I click on the "Register...
- Feb 09, 2021
SergeyGP wrote:
I can not configure the add-on ReadyNAS Photos II either.
That's because Netgear dropped the service (decommissioning the cloud servers required to make it work).
Ready Remote won't work either (and ReadyCloud requires a NAS than can run 6.x firmware).
You can't register used equipment. The purpose of registration is enable warranty and software support. But the warranty is not transferrable (and long expired, since Netgear stopped manufacturing your NAS in 2013). On top of that, Netgear's policy is not to provide software support / service contracts for used equipment.
Feb 09, 2021Guru - Experienced User
- SergeyGPFeb 09, 2021Aspirant
Thank you.
