barryd
Nov 25, 2016Aspirant
Remote access on 102
Hello I have a client with a 2 bay 102 device. Not sure at the moment what firmware its running but its been in place two or three years, I suspect its not been updated. They have a second s...
Nov 25, 2016Guru - Experienced User
ReadyCloud is one option, but you'd need to upgrade the firmware before you set it up. http://kb.netgear.com/app/answers/detail/a_id/31221/~/readynas-os-6-software-version-6.6.0?cid=wmt_netgear_organic
Note the warnings in the link above - if the firmware is old, you will need to upgrade in steps.
Another option is to set up a VPN between the two sites (though that likely requires upgrading the routers). Then everyone would access the NAS directly (and would also have full access to the combined network).
If they have the resources, they should consider a backup RN102 in the new office.
