barryd
Nov 25, 2016Aspirant
Remote access on 102
Hello I have a client with a 2 bay 102 device. Not sure at the moment what firmware its running but its been in place two or three years, I suspect its not been updated. They have a second s...
barryd
Thanks. I seem to remember Readycloud being mentioned when I set it up so what firmware is needed to run it? Last time I upgraded the firmware on one of these it caused all sorts of issues. I think it might be 6.2.5 but could be later.
Is there a guide anywhere to setting up Readycloud and what it does?
Nov 25, 2016Guru - Experienced User
- barrydNov 25, 2016Aspirant
thats great Stephen thanks.
Ill read it all later but just so I am clear once installed will I be able to put a shortcut on the two computers in the remote office to the shared documents folder on the Readynas in the main office? Just like they currently have locally?
EDIT: at the moment they dont have to put in passwords or anything, its just an open share. Would like to keep it that way
- FramerVNov 26, 2016NETGEAR Employee Retired
Hi barryd,
You would need to use the ReadyCloud desktop app or visit readycloud.netgear.com in order for you to access the ReadyNAS remotely.
Using the traditional site to site VPN will most likely allow you to add a shortcut (mapped drive).
- FramerVNov 27, 2016NETGEAR Employee Retired
Hibarryd
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards,- barrydNov 29, 2016Aspirant
Thanks for the further replies. Still looking into it as the internet connection at one end is at the moment via a 3g router and unreliable. We are looking to upgrade that to a wifi system (NO adsl available) so not sure about a VPN.
