FloodlightMedia
May 31, 2016Aspirant
Remote connectivity issues after upgrading to 6.5.0
Hi, After upgrading to 6.5.0 I naturally had to create and upgrade to a MyNetgear account to use ReadyCloud on our 2 NAS boxes. At first this was a major headache because it broke absolutely all ...
- Jun 21, 2016
Factory default reset fixed the issue at hand, as well as a number of other old niggling problems such as certificate errors that made browsers freak out every time I tried to view the admin page, and shutdown times of around 5 minutes (something about this device really hasn't aged well over a year or so).
Effective as it is though, it's hard to recommend factory default resets to many people. Backing up 18TB over a gigabit connection is not fun. Still, it's not Netgear's fault that 10Gbe is so crazy expensive.
mdgm-ntgr
May 31, 2016NETGEAR Employee Retired
Can you open a support case and let me know the case number?
Also you can attach the PoP (invoice) to the case that would be useful too.
FloodlightMedia
Jun 01, 2016Aspirant
The invoice might be a bit difficult to dig up as I support the office remotely most of the time. Was there any specific information you were after?
- StephenBJun 02, 2016Guru - Experienced User
Sometimes support needs to check proof-of-purchase, esp. if there is a big gap between the manufacture date and the purchase date.
