FloodlightMedia
May 31, 2016Aspirant
Remote connectivity issues after upgrading to 6.5.0
Hi, After upgrading to 6.5.0 I naturally had to create and upgrade to a MyNetgear account to use ReadyCloud on our 2 NAS boxes. At first this was a major headache because it broke absolutely all ...
- Jun 21, 2016
Factory default reset fixed the issue at hand, as well as a number of other old niggling problems such as certificate errors that made browsers freak out every time I tried to view the admin page, and shutdown times of around 5 minutes (something about this device really hasn't aged well over a year or so).
Effective as it is though, it's hard to recommend factory default resets to many people. Backing up 18TB over a gigabit connection is not fun. Still, it's not Netgear's fault that 10Gbe is so crazy expensive.
FloodlightMedia
Jun 01, 2016Aspirant
The invoice might be a bit difficult to dig up as I support the office remotely most of the time. Was there any specific information you were after?
Jun 02, 2016Guru - Experienced User
Sometimes support needs to check proof-of-purchase, esp. if there is a big gap between the manufacture date and the purchase date.
