4xholic's avatar
4xholic
Remote or readyCloud
Sort of new, setup my NAS several months ago, have access and all mostly works - having some remote connection issues with readyCloud but connect fine with readyNAS remote. I have an idea of the issu...
  • 4xholic's avatar
    4xholic
    Jan 30, 2017
    Hello JennC,
    I was on a trip and had no access to try anything until recent. Here is what I had to do.
    - Logged into Netgear account and remove the NAS
    - Logged in to Netgear Remote account and delete it
    - Logged back in to Netgear account and search/find my NAS by serial number
    - Logged in to my NAS and turn cloud back on and registered with my Netgear account
     All is working now. The solution came from Deniro in a private message after reviewing the logs I sent. Apparently, my account did not fully migrate over. Hope this helps someone else if they are having the same issue.
    Thank you for your support.
ProSupport for Business
