BBuzz's avatar
BBuzz
Apprentice
Jun 04, 2017
Can't upload remotely using ReadyCloud
Trying to upload images from windows 10 OS using ReadyCloud. Always been able to but not anymore. Multiple files immediate error, 1 file seems to proceed with upload then errors during cloud sync.  I am able to download from the NAS to the same windows 10 OS without any problem but not letting me upload.
  • BBuzz's avatar
    BBuzz
    Jun 08, 2017
    Uninstall and re-install Chrome. That did it for me.
  • BingkeX's avatar
    BingkeX
    NETGEAR Expert
    Hi BBuzz,
    Which browser do you use? And what is your nas firmware version?
    Would you please attach the screenshot when you see the error?
    Best Regards.
    • BBuzz's avatar
      BBuzz
      Apprentice
      Chrome Browser, Firmware 6.7.4  When the file gets to cloud sync it seems (from the speed of past uploads) choke and hesitate then the error appears. I have two different NAS's at that location both the same model and rebooted both reset the router and can't upload to either. This problem just started this weekend. Otherwise everything has been fine. I can access both and download from both.
      • BBuzz's avatar
        BBuzz
        Apprentice
        Okay I tried the Microsoft browser and I got it to upload. I am hoping someone can tell me what I need to do to fix Chrome so it will let me upload again.
  • I am having the same problem with Chrome. I have always used it to upload files remotely, and now this week I keep getting an error. I just tested Firefox and it worked there.
    • BingkeX's avatar
      BingkeX
      NETGEAR Expert
      Would you please  uninstall chrome and reinstall it and then try again?
      • BBuzz's avatar
        BBuzz
        Apprentice
        That is what you need to do. Unistall Chrome and then Re-Install Chrome. THat is what worked for me. Thanks for all your help.
    • BBuzz's avatar
      BBuzz
      Apprentice
ProSupport for Business
