BBuzz
Nov 12, 2017Apprentice
readycloud uploading failures
I started uploading files on readycloud early this morning and was sucessful. about 2 hours later I tried again and got failures It is stating in the failure that their was a connection error. Is the system down? Are their problems on the netgear cloud? I have tried different browsers Silverlight and reloaded Chrome with no success. This seemed to have started around 9:30am EST and am still not able to upload at 1:00pm EST Today is 11/12/17
- It seems that I had to go back in and delete the folders that I had created that I was trying to upload into for some reason during the creation of the folders they failed even though they were showing. So I went back in and deleted the folders recreated them and my uploads went through. So I would say that that was the solution to my problem
- BingkeXNETGEAR Expert
Hi BBuzz,
Do you try to upload file to nas or router via readycloud?
If upload file to a nas, what is your nas firmware?
And what is the file size of your uploaded fail files? Do you set quota for your shares?
Best Regards.
- BBuzzApprenticeIt seems that I had to go back in and delete the folders that I had created that I was trying to upload into for some reason during the creation of the folders they failed even though they were showing. So I went back in and deleted the folders recreated them and my uploads went through. So I would say that that was the solution to my problem
