BBuzz
Nov 12, 2017Apprentice
readycloud uploading failures
I started uploading files on readycloud early this morning and was sucessful. about 2 hours later I tried again and got failures It is stating in the failure that their was a connection error. Is the...
- Nov 13, 2017It seems that I had to go back in and delete the folders that I had created that I was trying to upload into for some reason during the creation of the folders they failed even though they were showing. So I went back in and deleted the folders recreated them and my uploads went through. So I would say that that was the solution to my problem
BingkeX
Nov 12, 2017NETGEAR Expert
Hi BBuzz,
Do you try to upload file to nas or router via readycloud?
If upload file to a nas, what is your nas firmware?
And what is the file size of your uploaded fail files? Do you set quota for your shares?
Best Regards.
BBuzz
Nov 13, 2017Apprentice
