BBuzz
Jun 04, 2017Apprentice
Can't upload remotely using ReadyCloud
Trying to upload images from windows 10 OS using ReadyCloud. Always been able to but not anymore. Multiple files immediate error, 1 file seems to proceed with upload then errors during cloud sync. I...
- Jun 08, 2017
Uninstall and re-install Chrome. That did it for me.
BingkeX
Jun 04, 2017NETGEAR Expert
Hi BBuzz,
Which browser do you use? And what is your nas firmware version?
Would you please attach the screenshot when you see the error?
Best Regards.
- BBuzzJun 05, 2017Apprentice
Chrome Browser, Firmware 6.7.4 When the file gets to cloud sync it seems (from the speed of past uploads) choke and hesitate then the error appears. I have two different NAS's at that location both the same model and rebooted both reset the router and can't upload to either. This problem just started this weekend. Otherwise everything has been fine. I can access both and download from both.
Okay I tried the Microsoft browser and I got it to upload. I am hoping someone can tell me what I need to do to fix Chrome so it will let me upload again.
- BingkeXJun 06, 2017NETGEAR Expert
Hello BBuzz,
I don't reproduce your issue with 6.7.4 firmware and with chrome browser version 58.x and 59.x.
What is the file size you want to upload? And does the uploading destination path have some special character?
You mean you can upload successfully with microsoft brower Edge? Would you please try to upload same file to same destination folder with chrome browser?
Best Regards.
