4xholic
Jan 16, 2017Aspirant
Remote or readyCloud
Sort of new, setup my NAS several months ago, have access and all mostly works - having some remote connection issues with readyCloud but connect fine with readyNAS remote. I have an idea of the issu...
- Jan 30, 2017
Hello JennC,
I was on a trip and had no access to try anything until recent. Here is what I had to do.
- Logged into Netgear account and remove the NAS
- Logged in to Netgear Remote account and delete it
- Logged back in to Netgear account and search/find my NAS by serial number
- Logged in to my NAS and turn cloud back on and registered with my Netgear account
All is working now. The solution came from Deniro in a private message after reviewing the logs I sent. Apparently, my account did not fully migrate over. Hope this helps someone else if they are having the same issue.
Thank you for your support.
4xholic
Jan 17, 2017Aspirant
It states it has already been upgraded. I was reading another post and they mentioned logging in to teh admin account via web - how is this done? As far as I know I only have 1 account. The email address associated with the old account is now the address on the myNetgear account. When I log into readycloud via the web I use this email/pw. However, will this conflict if one of the users on the NAS has the same email?
==[more]===
Here are the account setups now:
myNetgear: email1@...
NAS: Admin: no email, access when connect to same network via IP address
Acc1: email1
Acc2: email2
Cloud: email1
Tried changing email on Acc1, still cannot access. However, now readycloud says unit is offline - not sure the email change had anything to do with it or not.
Regarding the readyNAS remote, should I delete this??
JennC
Jan 25, 2017NETGEAR Employee Retired
Hello 4xholic,
ReadyNAS Remote is for legacy units such as ReadyNAS OS4 and OS5 units. You are using ReadyNAS 202 which is a ReadyNAS OS6. So, you would not be needing this ReadyNAS Remote.
