4xholic
Jan 16, 2017Aspirant
Remote or readyCloud
Sort of new, setup my NAS several months ago, have access and all mostly works - having some remote connection issues with readyCloud but connect fine with readyNAS remote. I have an idea of the issu...
- Jan 30, 2017
Hello JennC,
I was on a trip and had no access to try anything until recent. Here is what I had to do.
- Logged into Netgear account and remove the NAS
- Logged in to Netgear Remote account and delete it
- Logged back in to Netgear account and search/find my NAS by serial number
- Logged in to my NAS and turn cloud back on and registered with my Netgear account
All is working now. The solution came from Deniro in a private message after reviewing the logs I sent. Apparently, my account did not fully migrate over. Hope this helps someone else if they are having the same issue.
Thank you for your support.
4xholic
Jan 30, 2017Aspirant
Hello JennC,
JennC
Jan 31, 2017NETGEAR Employee Retired
Hello 4xholic,
I am glad it works now with the help of Deniro. We appreciate your patience in solving this. To close the topic, please mark the most appropriate post that helped you solved the concern you have raised as the accepted solution or you may also mark your post that has the summary of what you did.
Please feel free to post any comments, questions and suggestins.
