Xatosch
Oct 05, 2017Apprentice
Remote ShutDown via ReadyCloud
At Times where smart homes are not so expensive, it is easy via Philips hue to "plug in" a readynas device and access it a few seconds later via ReadyCloud, or for me to access the installed plex ser...
- Oct 06, 2017
In OS 6.9.0, you can set a power-down time without setting a power-on time. I'm not a ReadyCloud user so don't know if you can set that via ReadyCloud. If you can, just set it for the next hour when you finish using it. If you can't, you could at least set it to turn off at a specific time every night when you are away (just remmeber to disable it when you return).
A somewhat clunky way to implement that would be to use an UPS where the turn-off time and automatic power-on after power restoration can be set. Set the turn-off threshold of the NAS above that of the UPS. You turn the power off and when the UPS runs down to the set point, it signals the NAS to shut down. Of course, in a real power outage situation, this could be unwanted.
Another would be to also power on a PC where you can use one of the remote access methods to access the NAS local interface.
But the VPN solution is certainly the cleanest, You may also want to make a suggestion in the Idea Exchange that shut-down be allowed via ReadyCloud. Since for some that would be a bad idea, it definately would need an "are you sure", and maybe even an enable/disable of the function.
Oct 06, 2017Guru - Experienced User
Xatosch wrote:
On the admin page, there is a "shutdown", but I can not access the admin page over the internet...
Actually you can, if you enable HTTPS and forward a port for it in your router. You'd also need DDNS to reach your home network using a URL/name.
But it'd be better to start it up with wake-on-lan - for instance over OpenVPN so you could do that while away from home. A VPN would also be a better way to access the admin page (port forwarding has some security risks).
Sandshark
Oct 06, 2017Sensei
- XatoschOct 24, 2017Apprentice
I have tried VPN with my new Fritzbox 7490 and it works good, i can access via ip the admin page and gracefully shutdown the device and then via hue unplug the voltage.
