n_damian
Dec 30, 2015Aspirant
Remove devices from android ReadyCLOUD
I added Readynas to ReadyCloud and then I change HDD to new one. After installation system on new one, I added Readynas again to ReadyCloud. How to remove first one from android ReadyCLOUD? Via www ...
- Jan 03, 2016
Hi n_damian,
I have sent you a suggestion to try. Check your PM inbox.
JennC
Dec 30, 2015NETGEAR Employee Retired
Hello n_damian,
Sorry but your question is a bit confusing. What I understood is you changed the disks that were inserted to the ReadyNAS and re-enabled ReadyCloud again.
Please give me more detailed steps you have taken. ReadyCloud is a feature that you can disable and enable in the ReadyNAS admin page and it has nothing to do with adding or changing the disks inserted to the NAS.
- n_damianDec 30, 2015Aspirant
Android app shows 3 devices. Web gui shows 2 devices. rndu2 and rndu2000 is the same Readynas.
1. I added ReadyNas (rndu2000) to ReadyCloud.
2. Turn off ReadyNas and insert new hdd.
3. Turn on and reset device to factory default.
4. I added ReadyNas (rndu2) to ReadyCloud.Android app shows 3 devices. rndu2 and rndu2000 is the same Readynas. How to remove rndu2000 from android ReadyCLOUD list.
- BrianL2Dec 30, 2015NETGEAR Employee Retired
Hi n_damian,
Try to clear the cache of the app or uninstall/reinstall it.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
