n_damian
Dec 30, 2015Aspirant
Remove devices from android ReadyCLOUD
I added Readynas to ReadyCloud and then I change HDD to new one. After installation system on new one, I added Readynas again to ReadyCloud. How to remove first one from android ReadyCLOUD? Via www ...
- Jan 03, 2016
Hi n_damian,
I have sent you a suggestion to try. Check your PM inbox.
michaelg73
Jan 27, 2016Aspirant
Thanks Brian. The only device I am currently using is the ReadyNAS RN102. The firmware is 6.4.1. In the ReadyCloud App, it lists the ReadyNAS, but it also lists multiple WNDR4300 routers. I do have a WNDR4300, but I am runing DD-WRT on it, so no ReadyCloud support.
I figured out home to remove the unwanted routers, but every time I go into the App, it still lists them. I have cleared the App's cache. On the ReadyCloud website, the only device listed is the ReadyNAS.
Thanks,
-Michael
Thanks,
-Michael
JennC
Jan 28, 2016NETGEAR Employee Retired
Hello michaelg73,
Did you use the WNDR3400 with its orig firmware before?
What's the ReadyCloud app version are you using?
- michaelg73Jan 28, 2016Aspirant
Thankd JennC.
Yes, I did at one time use the WNDR4300 with original firmware on the ReadyCloud App. I don't remember having more than one listed before back when I used it previously.
I am using ReadyCloud 1.2.2.
It looks like all is well now. After removing the unwanted devices several times and clearing the App Cache and App Data, I am down to just the ReadyNAS in the ReadyCloud App.
Thanks again,
-Michael
- JennCJan 28, 2016NETGEAR Employee Retired
Hello michaelg73,
Oh that's good news that all is okay now. :)
Feel free to come back and post anything you have about ReadyNAS.
