n_damian
Dec 30, 2015Aspirant
Remove devices from android ReadyCLOUD
I added Readynas to ReadyCloud and then I change HDD to new one. After installation system on new one, I added Readynas again to ReadyCloud. How to remove first one from android ReadyCLOUD? Via www ...
- Jan 03, 2016
Hi n_damian,
I have sent you a suggestion to try. Check your PM inbox.
JennC
Jan 28, 2016NETGEAR Employee Retired
Hello michaelg73,
Did you use the WNDR3400 with its orig firmware before?
What's the ReadyCloud app version are you using?
michaelg73
Jan 28, 2016Aspirant
Thankd JennC.
Yes, I did at one time use the WNDR4300 with original firmware on the ReadyCloud App. I don't remember having more than one listed before back when I used it previously.
I am using ReadyCloud 1.2.2.
It looks like all is well now. After removing the unwanted devices several times and clearing the App Cache and App Data, I am down to just the ReadyNAS in the ReadyCloud App.
Thanks again,
-Michael
- JennCJan 28, 2016NETGEAR Employee Retired
Hello michaelg73,
Oh that's good news that all is okay now. :)
Feel free to come back and post anything you have about ReadyNAS.
