TylerMJ
Jul 04, 2022Aspirant
RN102 - My share folders disappeared
Hello community,
I searched a lot for a solution to my problem, but I didn't find exactly my problem, nor a satisfactory answer.
So I will describe here my problem and how I got there.
It i...
Jul 04, 2022Guru - Experienced User
TylerMJ wrote:
PS / I did a disk test and a rebalancing, but that obviously didn't help
You must have an OS-6 NAS then, not a Duo (which would either run 4.1.x firmware or 5.3.x firmware).
Can you double-check the model number?
Also, it would be helpful to know what firmware you are running.
- TylerMJJul 04, 2022AspirantHello,
Thank you for your answer.
My firmware : 6.10.7
Serial number : 3ER134EX010B5
Thank you for your help
Tyler- StephenBJul 04, 2022Guru - Experienced User
TylerMJ wrote:
My firmware : 6.10.7FWIW, I don't work for Netgear, so the serial number does not help me.
You can see the NAS model on the first page of the Admin Web UI. Likely something like
- ReadyNAS 102
- ReadyNAS 202
- ReadyNAS 212
- ReadyNAS 312
- ReadyNAS 422
It would also be a good idea for you to download the full log zip file from the logs page of the web ui. That will likely have the clues needed to figure out what happened. The logs do roll over from time to time, so it is best to get them early.
It's the ReadyNas 102
Sorry, it's not allowed to post zip files here.
Is there a specific log file that will help ?
Thank you
