jrmitchell001
Jan 07, 2017Aspirant
RN102 Cloud Error: Services Offline (Cannot Attach Device)
Ok, getting fed up with this... RN102 on a R7000 Nighthawk router, and cannot get the NAS to come up on cloud and access remotely, will only do local I have searched high and low on this foru...
- Jan 10, 2017
There were some issues with a configuration file as you last did a factory reset on some very old firmware on this box. I manually fixed this config file. Hopefully that has resolved it. If not further investigation will be required.
jrmitchell001
Jan 27, 2017Aspirant
Well after a couple weeks I'm happy to report that the manual fixes mdgm made have been working. Still not sure how or why this was such a problem, and hopefully the NETGEAR team can provide an automated fix in lieu of a manual one, but in the mean time, if anyone finds themselves having fits with services being unavailable, and is a novice home network techie, the fix may be beyond your expertise, and will want to contact the team here.
Thanks again for the help mdgm, much appreciated.
Jason
Suffolk, VA
vandermerwe
Jan 29, 2017Master
I have the same error appearing, I'm assuming there are several possible causes, but I shuddered when I read the comment that you had not factory defaulted for a while. I have not factory defaulted since 6.1.5 and I really hope that a factory reset doesn't become a solution. Is there perhaps a way for a user to diagnose and fix this using ssh mdgm?
