mariokappa
Feb 10, 2016Aspirant
RN10200 backup button doesn't work
Hello everybody,
here is my problem:front button "Backup" stopped working.
If i manually launch backup from dashboard,everything works well,i have only one backup in the list.
If i press the frontal backup button,in the dashboard i can see that readynas receive the command,but nothing happens,no errors and backup doesn't start.
I have this problem only this month,5 or 6 weeks ago everything was ok,and i didn't touch anything...no updates,nothing...firmware 6.4.2
Someone can help me?
thank you
Perhaps try deleting the backup button sequence and then recreate it. In the web ui select backup, then the backup button icon.
- mariokappaAspirant
I already tried to cancel the process and recreate it but no way,didn't work.
Thank you for helping me
- JennCNETGEAR Employee Retired
Hello mariokappa,
Welcome to the community!
I suggest contacting support center as it may need to be checked by higher tier remotely.
