Dim06
Jan 20, 2016Aspirant
rn104 cant access after firmware update
Hi Folks Would appreciate some help. I recently tried to access my RN104 NAS box using ReadyCloud through Edge browser. It prompted me to upgrade my firmware. When I did this it sucessfully downl...
- Jan 21, 2016
This is not that uncommon for only connecting via hostname to work on one Windows system and for only connecting via I.P. to work on another. Sometimes when there is a Windows update it may break access via one method and fix it for the other.
mdgm-ntgr
Jan 20, 2016NETGEAR Employee Retired
Does the NAS show up in RAIDar? If so, what do you see?
Can you download the logs using RAIDar and send them to me (see the Sending Logs link in my sig)?
- Dim06Jan 21, 2016Aspirant
Many thanks for the reply, really appreciated
Yes the NAS can be found on RAIDar and its now visible in Explorer. However when I try to get the logs or any other action in RAIDar I get a message that the NAS is not accessible from this compputer. Also when I try to access from Explorer it tells me it "can not access NASBox" and running diagnotics doesn't achieve anything
Also havent been able to access the NAS from any of the other computers on the home network for sometime
