gso
May 14, 2018Guide
RN212 Admin Password
Can no longer access my Admin page. For the lat few weeks there was a suggested URL to connect but now I just get a message sayong I must be on the same network... how do I resolve this? Thanks.
- May 16, 2018
since I have no idea how to get back to accessing the Admin page thru the Manage page, in ReadyCloud, I'll just use Raidar. Thanks all.
gso
May 15, 2018Guide
Yes, I'm using the ReadyClound Mac app.When I click on "Admin" it used to ask me for my password but more recemtly it gave me the link to the URL. Now it just says I need to be on the same network (not sure how to check this.)
Marc_V
May 15, 2018NETGEAR Employee Retired
Hi gso
The message you are getting is just a notice it does not mean that you are out of your Network. This mught be an update using the Portal or the App but it does not change how you access your ReadyNAS Admin page when locally connected on your Network.
You can actually access the Admin page locally by entering the IP Address of the NAS on your browser (http://NAS.IP.ADDRESS)
The message you are getting also has the link, it is saying that if you are locally connected to your Network then you can use the following address provided on the message.
Other option is to go to discover tab of the ReadyCloud Portal, your NAS should show and a Manage button will be available. Clicking on the button will also direct you to the NAS Admin page using the NAS IP ADDRESS.
Hope this helps!
Regards
- gsoMay 15, 2018Guide
Using Discover/Manage got me to the Admin page, thank you. But the IP address is different than the one it was showing as a link before.
how do I find the IP address of my NAS?
- SandsharkMay 15, 2018Sensei
RAIDar is the best way for devices without a display. If the IP address is changing, you might want to look into reserving an address for it in your router. That is typically a better method than using a static IP address.
- Marc_VMay 16, 2018NETGEAR Employee Retired
That is correct, RAIDar will discover the NAS and provide information such as the IP Address.
Also, when you are getting the message on ReadyCloud the link being provided is also the NAS IP Address of your NAS.
Hope this helps!
Regards
- gsoMay 16, 2018Guide
