Retired_Member
Aug 19, 2019RN314 Readycloud
I have I laptop running Windows 7 Pro 64 bit and a Desktop with the same Operating system on my gigabit Network. The laptop logs into Readycloud with ease but the Desktop Readycloud App (latest) rein...
- bedlam1Aug 19, 2019Prodigy
You could try installing Java SE Runtime Environment 8u181 this fixed this issue for me.(this is in addition to "regular" Java)
- Retired_MemberAug 19, 2019
Thank you for that, Ive installed that Java Update, unistalled Readycloud, run a Registry cleaner then reinstalled Readycloud but sadly its still the same.
Regards Simon
Shame, I am no expert but other things to just try maybe:
Turn Off and then On "Readycloud" on the NAS in GUI "Cloud" settings
Maybe check for Java updates using their checker app
Reboot PC and maybe the NAS
