Retired_Member
Aug 19, 2019RN314 Readycloud
I have I laptop running Windows 7 Pro 64 bit and a Desktop with the same Operating system on my gigabit Network. The laptop logs into Readycloud with ease but the Desktop Readycloud App (latest) rein...
bedlam1
Aug 19, 2019Prodigy
You could try installing Java SE Runtime Environment 8u181 this fixed this issue for me.(this is in addition to "regular" Java)
- Retired_MemberAug 19, 2019
Thank you for that, Ive installed that Java Update, unistalled Readycloud, run a Registry cleaner then reinstalled Readycloud but sadly its still the same.
Regards Simon
- bedlam1Aug 19, 2019Prodigy
Shame, I am no expert but other things to just try maybe:
Turn Off and then On "Readycloud" on the NAS in GUI "Cloud" settings
Maybe check for Java updates using their checker app
Reboot PC and maybe the NAS
- Retired_MemberAug 19, 2019Yep tried that but no joy . Thanks for the ideas.
