Retired_Member
Aug 19, 2019RN314 Readycloud
I have I laptop running Windows 7 Pro 64 bit and a Desktop with the same Operating system on my gigabit Network. The laptop logs into Readycloud with ease but the Desktop Readycloud App (latest) rein...
Icewaterhot
Sep 05, 2019NETGEAR Employee Retired
Hi Fingerstoo,
I saw your screenshot, the same as my windows Home version, so it is very strange, you can try to install readycloud 1.16 version, then overwrite the installation version 1.17, try to see if this can be used. Please download and try again.
https://www.dropbox.com/sh/4dlbf9yrinzgj8q/AABOk2OnGmYMqiLgBxiGQ2__a?dl=0
- FingerstooSep 05, 2019Guide
thanks for trying icewaterhot
Screenshot of version 1.16 running.
icewaterhot
And here is reinstalled version 1.17 running! Or not properly?
Just out of interest why is the file size of ReadyCloud v1.16 is 42,909KB, whereas the latest version is 9,257KB? Netgear has been radically updating it or cutting something out!
You see the old version had the same problem!
Fingerstoo
- IcewaterhotSep 05, 2019NETGEAR Employee Retired
ReadyCLOUD V1.16 is the debug version, it is for you to try to see if there is this problem, if you install this 1.16 also has this problem, it may be a system problem(Is activation active?). Because the old version of TLS has not changed. ReadyCLOUD V1.17 is the release version.
