Mitsai
Jul 24, 2016Tutor
RN316 - Downloaded file is very small size after updated 6.5.1
Hi all, No one same situation after updated 6.5.1??? I could not download my files properly when I upgraded ReadyOS from 6.5.0 to 6.5.1. Before installed 6.5.1, I have no issues, conditions are gr...
JennC
Jul 26, 2016NETGEAR Employee Retired
Hello Mitsai,
How to do you check the files size? These files that you claim small size compared to its size before updating to 6.5.1, are you able to open them?
I noticed you are from Japan, would you like me to move your post to Japan board?
Welcome to the community!
Mitsai
Jul 26, 2016Tutor
Hi JennC,
Thank you for your response on my issue.
It is fine if somebody can response in Japan board.
Unfortunately I have never seen that solved similar problem in the past Japan board since lack of technical? I have no idea, therefore I asked here because a lot of professional responded. However, I understand you said we have region issue? may be. Anyway, Thanks for your advises.
Best regards,
