icyvran
Jan 10, 2018Tutor
Secure connection to http://readycloud.netgear.com HTTPS
Hi, Could Netgear please secure the http://readycloud.netgear.com website with a persistent HTTPS connection?. Right now the secure connection is established only while entering the username and ...
Marc_V
Jan 17, 2018NETGEAR Employee Retired
Hi icyvran
The ReadyCloud portal actually runs on HTTPS, all connections from apps, portal and back-end access are on HTTPS.
The reason actually that we see HTTP on the portal is for the NETGEAR Home routers where they also connect to ReadyCloud however, with their specifications they usually are having a hard time maintaining HTTPS connection due to certificates being updated from time to time. So seeing the portal on HTTP is just actually for the routers to be able to use its feature but ensuring back-end and other access is secured using HTTPS and VPN connections.
Hope this helps!
Regards
