rodcrit
Jun 14, 2016Luminary
services offline
my system was ( finally after update to 6.5.0 0 working all normally. cloud users were accessing system from pc app, portal and android app. went on holiday. during holiday there was a short...
- Jun 22, 2016
Hi Liea
just to clear up. thanks for your help in fixing this problem. you connected to my PC and could see my system and corrected a couple of things which were incorrect. quite how the power break of a few seconds changed things that were working perfectly OK before is a mystery to me - but all is OK now
thanks
Rod
JennC
Jun 14, 2016NETGEAR Employee Retired
Hello rodcrit,
What do you get when you login at readycloud.netgear.com? If it logs you in and shows you your NAS, what do you see under Manage? It should show you all the invited ReadyCloud users.
Have you tried turning the ReadyCloud OFF and ON?
- rodcritJun 14, 2016Luminary
Hi JennC
thanks for response - really appreciated.
when I log in to ready cloud portal - it says "my system" is offline - check internet.. the manage screen says the same thing. it doesnt get any further than that. ( my internet is fully active and working ).
on the local admin cloud tab - it is showing the readycloud as being on. when I set it to off - it goes to off and when I set it back to on it goes to on. but it still shows as offline on the portal login.
locally the system is working OK it is the cloud access that is a problem.
regards
Rod
- JennCJun 15, 2016NETGEAR Employee Retired
Hello rodcrit,
What ReadyCloud account is logged in to the admin page cloud tab ReadyCloud settings?
Is this already migrated to myNetgear account?
- rodcritJun 15, 2016Luminary
the admin account logged into the portal is a migrated account. all my accounts were migrated once I started to use the beta version some time ago.
does that answer the question.
I have noted some converstations on the community saying that the config files have been corrupted if power is lost and a factory reset is necessary to start the system again. is this true ? surely the config files are protected from corruption no matter what happens.... just by copying and archiving. then a function to restore if necessary
comments ?
Rod Crittenden
