HeathM
Oct 22, 2016Aspirant
ReadyCLOUD Services offline
A while a go I set up the ReadyCLOUD service from my mac and for a brief period I did have a stable connection but now I only get Services Offline, I've tried to reinstall the App and start the reinstallation, but every time I try to discover the NAS drive, it can never find it, inputting the serial number makes no difference, yet RAIDar has no problem in identifying the NAS. Tried pressing the Backup button for 5 seconds and then retrying, nothing!
I am using a ReadyNAS 202, currently on Firmware 6.5.1, Mac OS X El Capitan 10.11.6 tried using Safari and Chrome browsers.
Any ideas what I'm supposed to do now.
Thanks in advance.
Heath
FramerV wrote:
Try using google DNS' like 4.2.2.2 and 4.2.2.1.
Google's public DNS servers are 8.8.8.8 and 8.8.4.4.
4.2.2.1 and 4.2.2.2 belong to Level 3 Communications. I don't think Level3 has published them as open servers (at least I've seen no clear statement from them), though many people might be using them.
- FramerVNETGEAR Employee Retired
Hi HeathM,
There is a possibility that the ReadyNAS is not reaching our cloud servers. In most cases, setting a public DNS resolves it. Try using DNS' like 4.2.2.2 and 4.2.2.1 or Google's public DNS 8.8.8.8 and 8.8.4.4
Please check the link below on how to configure Ethernet interface on your ReadyNAS OS6:
http://kb.netgear.com/app/answers/detail/a_id/23074
Hi StephenB,
Thanks for the correction, I edited my post to avoid confusion.
- HeathMAspirant
Many thanks, input the values for 8.8.8.8 and 8.8.4.4 respectively and ReadyCLOUD is now back online.
Cheers
Heath
