rodcrit
Jun 14, 2016Luminary
services offline
my system was ( finally after update to 6.5.0 0 working all normally. cloud users were accessing system from pc app, portal and android app. went on holiday. during holiday there was a short...
- Jun 22, 2016
Hi Liea
just to clear up. thanks for your help in fixing this problem. you connected to my PC and could see my system and corrected a couple of things which were incorrect. quite how the power break of a few seconds changed things that were working perfectly OK before is a mystery to me - but all is OK now
thanks
Rod
rodcrit
Hi JennC
thanks for response - really appreciated.
when I log in to ready cloud portal - it says "my system" is offline - check internet.. the manage screen says the same thing. it doesnt get any further than that. ( my internet is fully active and working ).
on the local admin cloud tab - it is showing the readycloud as being on. when I set it to off - it goes to off and when I set it back to on it goes to on. but it still shows as offline on the portal login.
locally the system is working OK it is the cloud access that is a problem.
regards
Rod
JennC
Jun 15, 2016NETGEAR Employee Retired
Hello rodcrit,
What ReadyCloud account is logged in to the admin page cloud tab ReadyCloud settings?
Is this already migrated to myNetgear account?
- rodcritJun 15, 2016Luminary
the admin account logged into the portal is a migrated account. all my accounts were migrated once I started to use the beta version some time ago.
does that answer the question.
I have noted some converstations on the community saying that the config files have been corrupted if power is lost and a factory reset is necessary to start the system again. is this true ? surely the config files are protected from corruption no matter what happens.... just by copying and archiving. then a function to restore if necessary
comments ?
Rod Crittenden
- rodcritJun 16, 2016Luminary
Further to my queries and not heard any positive outcome of the problems I am having - I am contemplating having to do a factory reset and rebuilt my system after backing up all the data ( 3TB ).
at present my remote users ( in the USA ) cannot access their data on my system. the longer this goes on the worse it gets.
so further questions.
1. if the configuration files can be corrupted by a power failure, is there a way of saving copies of the config files so they can be restored if something like this fhappens again?
2. I have set up over 30 backup operations which will have to be reinstated when the ssytem is rebuilt. is there anyway of saving the backup scripts or whatever controls them so they can be reinstated without having to reinput all the backup operations.
finally - I dont want to have to reset my system - is there anyway of correcting the current situation?
Rod Crittenden
- LeiaJun 16, 2016NETGEAR Employee Retired
Hi Rod,
You said you used beta version, and you migrated your ReadyCloud accounts to MyNetgear accounts when you used beta version. May I ask what version of f/w you used?
And after you upgraded your NAS to 6.5.0, did you joined your NAS to ReadyCloud again with your MyNetgear account?
Which f/w your NAS is running now? And could you please try to leave ReadyCloud on admin UI Cloud page, and then re-join in again?
Thanks,
-Leia
When the final release was issued, I came off the beta and set up on the final release of 6.5.0.
Everything was working fine for the period from installing final release until a power outage at my home when I was away on holiday. Please note : everything was working.
I had rejoined the system and all my remote users were accessing my NAS system.
I have tried to leave and rejoin, but on clicking leave, the revolving circle appears for about 20 seconds and then goes leaving the system as before. The leave button is still there.
When I open the cloud tab at the top of the screen it reports internet available with tick.... a connection is tried for about 1 minute and then reports services offline with red cross.
I tried setting the on switch to off - and it goes off with no info at top of screen. I set it back to on - the settings and ‘leave’ button come back.... internet is available and services offline reported.
Please escalate this problem to the Netgear Support. I am getting really fed up with this whole system.
In the past 7 months my remote users have only had access to the system for about 2 of them because of problems with the firmware updates.
Will you also please answer my question regarding backup of config files and backup script files. I think I am going to have to reset this system and start again ( or throw it in the waste bin ! ).
Rod
