GavinMerwin's avatar
GavinMerwin
Setting up ReadyCLOUD
Hi there,    We use the ReadyNas 102 verison 6.2.4 as our network storage. On the admin page (by typing the host name/IP in a browser) under "Accounts" we set up users. I'm interested in using th...
  • Marc_V's avatar
    Jan 16, 2019
    Hi GavinMerwin
    Welcome to the Community!
    ReadyCloud now uses your MyNETGEAR Account to sign in to the service. I would suggest to finish updating your ReadyNAS before using the ReadyCloud service and login using your MyNETGEAR Account. If what you have is not a MyNETGEAR Account you may want to upgrade it. You can check the FAQs here.
    Yes ReadyCloud uses VPN and is secured, you may need to make changes to your firewall if it is not allowing any incoming connections and also your Security software installed on your computers.
    You should be able to setup your ReadyCloud once you have updated to the latest firmware.
    Hope this helps!
    Regards
ProSupport for Business
