WellsBDandC
Aug 28, 2020Tutor
Sync issues from onedirve to ReadyNAS 6.10.3
Hi we have a our business set up on a readyNAS 6.10.3 with bidirectional sync to onedrive. Recently when working from home using one drive we are finding that it is not syncing with the readyNAS when...
JohnCM_S
Aug 29, 2020NETGEAR Employee Retired
Hi WellsBDandC,
Welcome to the Community!
You can try leaving then rejoining the NAS to OneDrive and see if that helps.
You may also download the complete system logs of the NAS and then check the one-drive.log. You might find some clues there on what is causing the sync issue.
