WellsBDandC
Aug 28, 2020Tutor
Sync issues from onedirve to ReadyNAS 6.10.3
Hi we have a our business set up on a readyNAS 6.10.3 with bidirectional sync to onedrive. Recently when working from home using one drive we are finding that it is not syncing with the readyNAS when...
JohnCM_S
Sep 01, 2020NETGEAR Employee Retired
Hi WellsBDandC,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as a solution so others can be confident in benefiting from the solution.
The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
WellsBDandC
Oct 06, 2020Tutor
Hi JohnCM_S
We have tried leaving and returning and it will work for a day or two. Then after doing work at home and returning to the office the next day to find that the file we worked on during the night hasnt updated on the readyNAS.
Cheers
- JohnCM_SOct 07, 2020NETGEAR Employee Retired
Hi WellsBDandC,
Can you download the NAS system logs then provide it to me so we can check it? You may upload it to a file-sharing site then send me the download link via private message.
