BrandinE
Feb 01, 2017Follower
View all existing web links on readycloud device
Hello,
I have been searching a round a bit and cant seem to find an answer to my seemingly easy question. Where can I list off/manage all Weblinks for sharing created within the Readycloud site? I want to be able to view any existing links for a folder and if possible accross the entire device. Currently I can only seem to create new links for a folder if I right-click on it, not view or manage any previous..
Thank you.
- JennCNETGEAR Employee Retired
Hello BrandinE,
You may check under Manage tab of ReadyCloud portal when logged in using ReadyCloud account that has the admin rights. This I believe should show the web links you shared. But to manage the access of a certain user, you can simply change it from the Home tab and click each share that you would like to add or remove user/s for accessing it.
- FramerVNETGEAR Employee Retired
Hi BrandinE,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
