mvlaran
Oct 11, 2022Aspirant
Volume Degraded without errors
Hello! I have a ReadyNas 104 with 2 WDC WD40EFRX-68WT0N0 4TB NAS HDs. Out of the blue, the system started to show the 2nd HD as DEGRADED. I have destroyed, reseted the hole system and for...
Oct 11, 2022Guru - Experienced User
mvlaran wrote:
Any suggestions on what to do?
Replace the disk.
Getting another WD40EFRX is fine, you could also get a 4 TB Seagate Ironwolf. Avoid the WD40EFAX, as it is SMR.
mvlaran wrote:
If I plug the HD in another CPU, I can format and use the HD without any warnings or errors.
Not a definitive test. You could try testing it with WD's dashboard software. But it's pretty clear that the NAS is not happy with the disk.
- mvlaranOct 11, 2022Aspirant
That's what I'm thinking, replacing the disc! I've already disconnected it.
Is it possible to downgrade the RAID 1 to JBOD so the unit stop flashing "DEGRADED" all over while I can't afford a new disc? (I'm brazillian, it's very expensive to buy a new HD now... I will have to wait a few months until I can get a new one.- StephenBOct 11, 2022Guru - Experienced User
mvlaran wrote:
Is it possible to downgrade the RAID 1 to JBOD so the unit stop flashing "DEGRADED" all over while I can't afford a new disc?If you are using the web ui, that would require destroying the volume and creating a new one. You'd need to reinstall any apps, recreate the shares, backup jobs, and similar stuff. And restore all the data from a backup.
There is a way to do it with the linux command line (ssh), but I don't recommend going that route unless you already are comfortable with linux. Also, it's best to make sure you have an up-to-date backup if you go that route.
FWIW, you should make sure you have your important data backed up anyway, as it is quite possible that disk 1 will fail while you are waiting.
I'm quite comfortable with linux / unix. If you have a how-to, I would like to try.
I have another backup solution besides nas, so my data is not (so much) uncovered!
