Lucha's avatar
Lucha
What is my server address???
I downloaded an app to see if i can access my ready as faster via this app on my iphone
Iys asking for my server address which i dont know what it is
Also for my name and password help!!
  • StephenB's avatar
    What app?  Are you expecting it to work over your home WiFi, or are you expecting it to work when you are away from home?
  • App is called owncloud
    Its asking for my server address for my nas
    What would that be?? Yes i know my username and password
    • StephenB's avatar
      You need to install the owncloud server app on the NAS, and the owncloud client app on the iphone.
      You'll also need to forward the appropriate ports in your router to the NAS, and also get a ddns name that points to your router (noip still offers a free service).
      I don't use owncloud myself, so hopefully someone does can point you to a suitable guide.
  • Thank you but that sounds hard to do
    All the apps are so slow to access my photos
    The ready cloud app is so slow
    Im looking for an easy app to look at my photos and music
    • StephenB's avatar
      Most of the ways of doing this (other than readycloud) will require either getting a DDNS name for your router, or port forwarding - or both.
      Is the goal simply to view photos/listen to music that is stored on the NAS?
      If so, plex is one option - it requires port forwarding, but not DDNS.
    • Sandshark's avatar
      Sandshark
      Sensei
      It's not for the faint of heart.  Which NAS do you have?  ZeroTier may meet your needs better, but the ReadyNAS app is only available for OS 6.6.0 and up.
      But if ReadyCloud and ReadyNAS Photos are slow, it's likely because the upload speed provided by your ISP is slow and nothing except a more expensive service tier from them is going to solve it.
      • capaz's avatar
        capaz
        Tutor
        FWIW, just pointing out that the OP hasn't answered StephenB's question: "Are you expecting it to work over your home WiFi, or are you expecting it to work when you are away from home?"  If it's the first, then all this scary talk about routers and ports might not be necessary.
        Edit: correction
ProSupport for Business
