Vette73
Sep 18, 2018Follower
Why is Readycloud remote not https?
Subject asks the question. Why does ReadyCloud not connect to a secure server?
JohnCM_S
Oct 02, 2018NETGEAR Employee Retired
Hi Vette73,
This was actually asked before. You may find the answer to this question on this thread.
- JohnCM_SOct 05, 2018NETGEAR Employee Retired
Hi Vette73,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
Regards,- schumakuOct 06, 2018Guru - Experienced User
Well, its the way it is for now - however this can't be considered resolved. Even complex Web App environments must be workable with a https front end.
- StephenBOct 07, 2018Guru - Experienced User
I agree. For many businesses, HTTP is a non-starter, no matter what assurances are given about the back end. Consumers might be more tolerant at the moment, but I don't think that will last.
It seems to me that it would be possible to segment the ReadyCloud frontend so that it uses only HTTPS with ReadyNAS (and higher-end Nighthawks).
