mdlaat's avatar
mdlaat
4.2.19 apt-get key missing
Hi,
I just got myself a Ultra 2. Trying to install gcc and others, but apt-get give me an error:
# apt-get update
Get:1 http://archive.debian.org etch Release.gpg [1033B]
Hit http://archive.debian.org etch Release
Ign http://archive.debian.org etch/main Packages/DiffIndex
Hit http://archive.debian.org etch/main Packages
Get:2 http://www.readynas.com 4.2.19/ Release.gpg [490B]
Hit http://www.readynas.com 4.2.19/ Release
Err http://www.readynas.com 4.2.19/ Release
Get:3 http://www.readynas.com 4.2.19/ Release [738B]
Ign http://www.readynas.com 4.2.19/ Release
Ign http://www.readynas.com 4.2.19/ Packages/DiffIndex
Hit http://www.readynas.com 4.2.19/ Packages
Fetched 1229B in 1s (849B/s)
Reading package lists... Done
W: GPG error: http://www.readynas.com 4.2.19/ Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY B7F02108D553259A
W: You may want to run apt-get update to correct these problems
Does anybody have a similar problem and/or knows how to correct it?
Thanks
Maurice
  • This is remarkably frustrating. All I want to do is update my SVN from 1.4.x to 1.7.x. I'd like to do it using apt-get but this key issues is completely in the way. apt-get is one of the beautiful things about ubuntu and it's totally neutered by what appears to be a fairly simple problem for the fine folks at Netgear to fix. Right?
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    The ReadyNAS uses customised Debian, not Ubuntu, but Ubuntu is based on Debian.
    chirpa said the issue was fixed earlier in the thread. You're running the production 4.2.20 and still have the issue? What happens when you do the following?:
    apt-get update
    apt-get update
    I was sure this was fixed? I recall Stefan and Chirpa posting that they fixed it, and it was then working?
    I've just had to run a Factory reset and I'm now setting it all up again to how I need/like it, but it is now giving me this problem again. (4.2.20.)
    W: GPG error: http://www.readynas.com 4.2.20/ Release: The following signatures were invalid: BADSIG B7F02108D553259A RAIDiator Release Key <admin@readynas.com>
  • Hi all!
    I have been traying the beta 4.2.20-T42 and it is not working for me with apt-update.
    Is there anything more to do to make it work, than update the Readynas to 4.2.20-T42 fw?
ProSupport for Business
