rikstigter1's avatar
rikstigter1
6.1.3. and SabNZB
I'm experiencing difficulties after upgrading to 6.1.3. on a RN104 with SabNZB (0.7.16-0rnx1).
The problem is that the system comes to a standstill after several hunderds of MB downloaded. This worked fine with 6.1.2. and reverting solved the problem. Two questions:
- Does anyone have the same problem?
- Whom should I contact?
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    What model ReadyNAS is this on? Have you tried contacting the developer who made this add-on?
  • This is on a RN104 (ARM), as stated. I haven't yet contacted the developer, but I shall.
    Update: I put this message on their support forum: http://rnxtras.com/topic/rn104-sabnzbd-problem-with-fw-6-1-3
  • We've been discussing things a bit on the other forum (http://rnxtras.com/topic/rn104-sabnzbd-problem-with-fw-6-1-3), but the developer cannot replicate the problem on a RN102. Somebody else on a RN104 had the same problem and in his case it also disappered after a roll-back to 6.1.2, so it may be hardware related.
    I've been looking through some of the config- and log-files, but I cannot find anything interesting as yet. Any suggestions to where I might look specifically?
ProSupport for Business
