Badyoda
Oct 14, 2013Aspirant
Rn102, problems after installing 6.1.3
Having some problems after upgrading to 6.1.3...
Apps randomly dissapears, need to cut power for them to reappear ( like plex, transmission)
Cannot restart device from user gui, need to push power button (if I try restarting from gui device wont start properly, need to cut power)
All in all the device is behaving wierd and often very slow...
Anyone having similar problems? Anyone have any idea on how to fix this? Reinstall os from bootmenu perhaps?
- BadyodaAspirantSome other problems noticed:
Mediaplayers on my ipad, 8player, plex and airplayer cant see some files and folders. I can see them fine in windows and in NAS UI.. This is wierd.
Tomorrow im gonna try reinstalling os... - StephenBGuru - Experienced UserAre you running the plex server or readydlna?
- UteDohrsAspirant
Badyoda wrote: Some other problems noticed:
see here:
viewtopic.php?f=76&t=73440
...but nobody seems to be interested in this BUG..... :-( - BadyodaAspirant
Hm I'm a NASnoob so i really don't know... But i run the app plex on my NAS but i use the NASserver in 8player (I'm guessing thats readydlna) - BadyodaAspirant
UteDohrs wrote: Badyoda wrote: Some other problems noticed:
see here:
http://www.readynas.com/forum/viewtopic.php?f=76&t=73440
I toogled tivo off/on and readydlna off/on and now all files shows in 8player! Thanks! 1 problem solved... - BadyodaAspirantTried Plex on iPad, no change. cant see all files even though I toogled the plex app off/on in NAS UI..
- StephenBGuru - Experienced UserYou have two DLNA servers running and multiple apps, so I am not clear on exactly what you are saying.
Just to clarify - some files are not showing up when you use the plex server, but they are showing up when you use the readydlna server? Or are you saying that the iPad plex app is not showing some files with either ReadyDLNA or plex? - BadyodaAspirantOk.
I changed some filenames on my 102 and after that they wouldnt show up in 8player (DLNA right?) This was corrected by toggling DLNA off and on (I did that with Tivo also so I dont know which did the job tbh..)
Plex on iPad didnt show recently added files (movies), I'm guessing that plex on iPad uses DLNA too? When I'm checking now plex on iPad doesnt show jack shit for some reason, atm I'm reinstalling 6.1.3 manually.
The UI is really acting strange with apps dissapearing now and then and services not showing etc etc.
Ill get back when Ive reinstalled OS.
Am I the only one having these issues? - BadyodaAspirantI forgot to mention that I had trouble installing new OS the first time, I ended up chatting with support. Now that I reinstalled OS the same thing happened, got a message saying "couldnt restart... dont reboot...call support..."
Can I install the old OS again since that worked? - StephenBGuru - Experienced Useri guess I am still confused about whether you are using the plex DLNA server on the RN102 or not.
