Badyoda
Oct 14, 2013Aspirant
Rn102, problems after installing 6.1.3
Having some problems after upgrading to 6.1.3... Apps randomly dissapears, need to cut power for them to reappear ( like plex, transmission) Cannot restart device from user gui, need to push power...
Oct 17, 2013Guru - Experienced User
You have two DLNA servers running and multiple apps, so I am not clear on exactly what you are saying.
Just to clarify - some files are not showing up when you use the plex server, but they are showing up when you use the readydlna server? Or are you saying that the iPad plex app is not showing some files with either ReadyDLNA or plex?
