Badyoda's avatar
Badyoda
Rn102, problems after installing 6.1.3
Having some problems after upgrading to 6.1.3...
Apps randomly dissapears, need to cut power for them to reappear ( like plex, transmission)
Cannot restart device from user gui, need to push power button (if I try restarting from gui device wont start properly, need to cut power)
All in all the device is behaving wierd and often very slow...
Anyone having similar problems? Anyone have any idea on how to fix this? Reinstall os from bootmenu perhaps?
  • StephenB's avatar
    Ok. Maybe when things settle down with OS6 stability, you can try turning off the ReadyDLNA service, and see if using just the plex server works out better [or worse].
  • Ok so I went back to 6.1.2 and now everything works just fine :)
    Guess I'll wait for 6.1.4...
  • Badyoda wrote:
    UteDohrs wrote:
    Badyoda wrote:
    Some other problems noticed:
    Mediaplayers on my ipad, 8player, plex and airplayer cant see some files and folders. I can see them fine in windows and in NAS UI.. This is wierd.
    Tomorrow im gonna try reinstalling os...
    see here:
    viewtopic.php?f=76&t=73440
    ...but nobody seems to be interested in this BUG..... :-(
    I toogled tivo off/on and readydlna off/on and now all files shows in 8player! Thanks! 1 problem solved...
    But this Bug is NOT fixed in 6.1.4 RC1 and RC2 ..... waiting for 6.1.4 RC3 :-)
ProSupport for Business
