viperhansa's avatar
viperhansa
Virtuoso
Dec 16, 2012
SABNzb not downloading.
Hi all.
Is there someone more with download problems?
Whatever i try i get "Download failed - Out of your server's retention? "
i am using astraweb and giganews..
// Hansa
  • If this is happening for every file you attempt to download, check the retention setting for SABNZBD+ for your configured servers.
    Don't forget that the NZB might be found by your search provider (NZBsRus, etc.) that doesn't mean to say it will be available on your provider. SABNZBD does have the ability to check the availability of a selected download before attempting the actual download, to save you bandwidth if the content is incomplete.
    Astraweb has a retention of about 1583 days for binary groups, and Giganews a maximum retention for binary groups of about 1700 days. However, for each NZB these values can and do fluctuate.
  • This is also the message you will get in some cases where the file (or parts of it) have been removed due to a DMCA takedown notice.
  • I have the same issue, think it happened after I upgraded from an upgrade on readynasextras.com
ProSupport for Business
